Introduzione
This guide will show how to add RAM or replace existing RAM on the Latitude D600
Parti
Nessuna parte richiesta.
Find the battery
  • Find the battery
Aggiungi Commento
Pull the tab to release the battery Pull the tab to release the battery
  • Pull the tab to release the battery
Aggiungi Commento
Pull the battery out
  • Pull the battery out
Aggiungi Commento
Find the panel underneath the microsoft product key sticker, the panel is labeled with an M Unscrew the single screw above the M
  • Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
  • Unscrew the single screw above the M
Aggiungi Commento
Pull off the panel to reveal the RAM RAM is held in by two tabs, pull each tab to the side and the RAM will pop up RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
  • Pull off the panel to reveal the RAM
  • RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
Aggiungi Commento
Once the RAM is popped up, slowly pull it out of the slot
  • Once the RAM is popped up, slowly pull it out of the slot
Aggiungi Commento
To add or replace RAM, place the memory into the slot at an angle Make sure you line it up correctly If it is in correctly it should stay up at an angle by itself
  • To add or replace RAM, place the memory into the slot at an angle
  • Make sure you line it up correctly
  • If it is in correctly it should stay up at an angle by itself
  • Then push down in the middle until it clicks into place
Aggiungi Commento
The RAM should be secured by the tabs where the two semi circles are on the RAM
  • The RAM should be secured by the tabs where the two semi circles are on the RAM
  • If it is not secure, just gently pull it out and try again, use the images to help you out
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Joseph
Membro da: 16/07/2014
1.373 Reputazione
6 Guide realizzate
Almost perfect: easy; clear;
Herman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,690
