Salta al contenuto principale
Dell Latitude 7390 Fan Replacement
Cosa ti serve
  1. Dell Latitude 7390 Fan Replacement, Bottom Panel: passo 1, immagine 1 di 1
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 Fan Replacement: passo 2, immagine 1 di 3 Dell Latitude 7390 Fan Replacement: passo 2, immagine 2 di 3 Dell Latitude 7390 Fan Replacement: passo 2, immagine 3 di 3
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 Fan Replacement: passo 3, immagine 1 di 1
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 Fan Replacement: passo 4, immagine 1 di 2 Dell Latitude 7390 Fan Replacement: passo 4, immagine 2 di 2
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 Fan Replacement: passo 5, immagine 1 di 1
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
  6. Dell Latitude 7390 Fan Replacement, Battery: passo 6, immagine 1 di 1
    • Make sure the laptop is turned OFF and unplugged from the power adapter before taking the battery out.
    • Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
  7. Dell Latitude 7390 Fan Replacement: passo 7, immagine 1 di 3 Dell Latitude 7390 Fan Replacement: passo 7, immagine 2 di 3 Dell Latitude 7390 Fan Replacement: passo 7, immagine 3 di 3
    • Be careful not to break the connector by pulling too hard on the black tab.
    • Pull the black tab on the top of the connector to unplug the battery from the motherboard.
  8. Dell Latitude 7390 Fan Replacement: passo 8, immagine 1 di 1
    • Carefully lift the battery out of the laptop.
  9. Dell Latitude 7390 Fan Replacement, Fan: passo 9, immagine 1 di 1
    • Remove the five black screws holding the fan and heatsink in place using the Phillips #0 screwdriver.
  10. Dell Latitude 7390 Fan Replacement: passo 10, immagine 1 di 1
    • Use tweezers or your fingers to disconnect the fan connector.
  11. Dell Latitude 7390 Fan Replacement: passo 11, immagine 1 di 1
    • Remove the fan from the case.
Conclusione
Altre 3 persone hanno completato questa guida.
Clemson, Team 1-4, Hunter Spring 2022 Membro di Clemson, Team 1-4, Hunter Spring 2022
CLEM-HUNTER-S22S1G4
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 59
Tutti i Tempi: 2,445
