Flip your laptop over to view the bottom and locate the two locks.
  • Flip your laptop over to view the bottom and locate the two locks.
Aggiungi Commento
Slide the two locks away from each other.
  • Slide the two locks away from each other.
  • Sliding these locks will loosen the battery to allow removal.
Aggiungi Commento
Pull battery out of the laptop. Your laptop's battery should be completely removed.
  • Pull battery out of the laptop.
  • Your laptop's battery should be completely removed.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Flip the laptop right side up.  Open the laptop. Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
  • Flip the laptop right side up. Open the laptop.
  • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
Aggiungi Commento
Gently flip the data cable latch away from the data cable with flat side of spudger. Lift the cable up and out. When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area.  When these are in place the cable is properly inserted.
  • Gently flip the data cable latch away from the data cable with flat side of spudger.
  • Lift the cable up and out.
  • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
  • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
What do I do is i broke the cable retainer wings and the black thing?
Wezley Joao Ferreira - Replica
If the connector on the motherboard is still attached and only the clip is broken you can try and find a new clip, or perhaps tape the keyboard in place with electrical tape.
Tyler - Replica
Close the lid, flip the laptop bottom side up with the battery at the top.
  • Close the lid, flip the laptop bottom side up with the battery at the top.
  • Remove the 11 screws holding the upper case to the lower case.
Aggiungi Commento
Flip the laptop over and open the lid.
  • Flip the laptop over and open the lid.
  • Remove the two screws from the upper case.
Aggiungi Commento
Gently unplug the power cable. You lift up on the dark gray latch. Pull the blue ribbon up.
  • Gently unplug the power cable.
    • You lift up on the dark gray latch.
    • Pull the blue ribbon up.
  • Gently unplug the touchpad cable.
    • Lift up on the dark gray latch.
Aggiungi Commento
Grab the metal frame of the upper case and gently pull it away from the lower case. Disconnect the cable that says MB before removing the palmrest.
  • Grab the metal frame of the upper case and gently pull it away from the lower case. Disconnect the cable that says MB before removing the palmrest.
  • Work your way around the perimeter of the upper case.
Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
Tyler
Membro da: 19/06/2012
3.997 Reputazione
18 Guide realizzate
TechForce Membro di TechForce
Business
2 Membri
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,251
