Parti
Nessuna parte richiesta.
Place the all in one computer face down on a soft, clean surface to avoid scratching the front. Press the tab on the stand cover and lift up. Press the tab on the stand cover and lift up.
  • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
  • Press the tab on the stand cover and lift up.
Aggiungi Commento
Remove the four phillips screws that attach the stand to the computer. Tilt the stand up and out. Tilt the stand up and out.
  • Remove the four phillips screws that attach the stand to the computer.
  • Tilt the stand up and out.
Aggiungi Commento
Starting from the optical drive, pry the back cover up with a plastic spudger. The cover is held in place by fragile plastic clips.  Careful to not break them. The cover is held in place by fragile plastic clips.  Careful to not break them.
  • Starting from the optical drive, pry the back cover up with a plastic spudger.
  • The cover is held in place by fragile plastic clips. Careful to not break them.
Aggiungi Commento
Remove the three screws that hold the hard drive cage to the chassis. Remove the three screws that hold the hard drive cage to the chassis.
  • Remove the three screws that hold the hard drive cage to the chassis.
Aggiungi Commento
Slide the hard drive cage out slightly to access and remove the power and SATA cable. There isn't much slack in these cables, so don't slide the hard drive cage to far.
  • Slide the hard drive cage out slightly to access and remove the power and SATA cable.
  • There isn't much slack in these cables, so don't slide the hard drive cage to far.
  • The power and SATA cables are connected together. On most other computers, these connectors are separate.
  • Lift the hard drive cage out.
Aggiungi Commento
Remove the four screws (two on each side) that attach the hard drive cage to the hard drive. Lift the hard drive cage off the hard drive. Lift the hard drive cage off the hard drive.
  • Remove the four screws (two on each side) that attach the hard drive cage to the hard drive.
  • Lift the hard drive cage off the hard drive.
Excellent guide, was a super easy swap. I put an SSD in it!!
Matt Yakel - Replica
Conclusione
Altre 23 persone hanno completato questa guida.
Tyler
Membro da: 19/06/2012
3.997 Reputazione
18 Guide realizzate
TechForce Membro di TechForce
Business
2 Membri
18 Guide realizzate
Thanks for this info this is very useful
Thank you once again
Ketan Valsangkar - Replica
Good Job, short and sweet and easy to follow
schmidtrg - Replica
Really useful information thank you.
Jessie Colon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 17
Ultimi 7 Giorni: 121
Ultimi 30 Giorni: 389
Tutti i Tempi: 19,410
