Introduzione
If your disk drive on your Dell Inspiron N5030 is not working, and you have tried the other options on the troubleshooting page, this guide will help you replace it with a new one.
Cosa ti serve
Turn the computer over on its back so the battery compartment faces towards you.
Place your fingers on the small buttons with arrows pointing outwards.
Push and slide the buttons outward to unlock the battery compartment.
Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
Use a Phillips #0 screwdriver to unscrew one 0.6 mm screw located just to the left of the disc drive.
Altre 3 persone hanno completato questa guida.
