Remove the battery
  • Remove the battery
Aggiungi Commento
Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
Aggiungi Commento
At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
  • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
  • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
  • Gently lift up the keyboard starting at the top of the frame
  • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
Aggiungi Commento
Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
  • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
Aggiungi Commento
  • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
Aggiungi Commento
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Marie K Bordley
Membro da: 30/09/2014
177 Reputazione
2 Guide realizzate
Ohio State, Team 1-1, Buehl Fall 2014 Membro di Ohio State, Team 1-1, Buehl Fall 2014
OSU-BUEHL-F14S1G1
4 Membri
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 38
Tutti i Tempi: 2,352
