Introduzione
This guide will teach you how to remove and replace the keyboard on your Dell Inspiron M5030.
Parti
Nessuna parte richiesta.
Remove the fourteen 7/16" screws from the bottom of the laptop using a #0 Phillips head screwdriver. Remove the two 5/16" screws from the bottom of the laptop using a #0 Phillips head screwdriver.
  • Remove the fourteen 7/16" screws from the bottom of the laptop using a #0 Phillips head screwdriver.
  • Remove the two 5/16" screws from the bottom of the laptop using a #0 Phillips head screwdriver.
If you are removing only the keyboard, you only need to remove two screws.
1 - Remove the screw to the immediate right of the INSPIRON M5030 label.
2 - To the top left of the INSPIRON M5030 label, there are two screws. Remove the left one.
I marked the two screw locations with green, for clarification.
- https://ibb.co/nz4rNG
- https://postimg.org/image/67kinagal/
Robert Johnson - Replica
Turn the laptop over and open the lid. Locate the three tabs just above the top row of keys on the keyboard (above the F1, F6, and PrntScr keys).
  • Turn the laptop over and open the lid.
  • Locate the three tabs just above the top row of keys on the keyboard (above the F1, F6, and PrntScr keys).
  • Push the leftmost tab down with the plastic opening tool, while lifting the left side of the keyboard with your other hand.
  • While continuing to lift the left side of the keyboard, push the other two tabs down, moving from left to right. This should loosen the keyboard.
for your last bullet, maybe clarify saying "push the next to tabs with the plastic opening tool…"
Katie Pepi - Replica
Once the top edge of the keyboard is loose, gently pull up on the keyboard. Do not pull the keyboard forcefully; it is still attached to the laptop by  a ribbon
  • Once the top edge of the keyboard is loose, gently pull up on the keyboard.
  • Do not pull the keyboard forcefully; it is still attached to the laptop by a ribbon
Aggiungi Commento
Locate the blue end of the ribbon seated in the connector on the motherboard. Lift up the black flap on the connector and gently pull the ribbon away from the connector parallel to the motherboard. Lift the keyboard up and off of the motherboard, detaching the blue end of the ribbon from the connector.
  • Locate the blue end of the ribbon seated in the connector on the motherboard.
  • Lift up the black flap on the connector and gently pull the ribbon away from the connector parallel to the motherboard.
  • Lift the keyboard up and off of the motherboard, detaching the blue end of the ribbon from the connector.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Ryan Moelter
Membro da: 17/04/2014
376 Reputazione
2 Guide realizzate
Cal Poly, Team 3-44, Maness Spring 2014 Membro di Cal Poly, Team 3-44, Maness Spring 2014
CPSU-MANESS-S14S3G44
4 Membri
6 Guide realizzate
Do you know any ways to replace 4 keys Spacebar,B,N and the Slash/Question Mark are broken plz help
Snapchat Hotdog - Replica
The keyboard is best handled as a whole part replacement. You can find M5030 replacement keyboards for about $10 on Amazon/eBay.
Robert Johnson -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 915
