Salta al contenuto principale
Dell Inspiron E1705 Battery Replacement
  1. Dell Inspiron E1705 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Dell Inspiron E1705 Battery Replacement: passo 2, immagine 1 di 2 Dell Inspiron E1705 Battery Replacement: passo 2, immagine 2 di 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
Conclusione
To replace your battery, follow these instructions in reverse order.
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 22-5, Maness Fall 2010 Membro di Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Membri
11 Guide realizzate
Un commento
I think it would be complete if we knew where to buy it as well.
Nobody would read up on changing a battery if he didn’t need one, so you might as well tell him where to get it.
I think that makes sense. However thank you for your effort.
kjanmunkedal - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 4,241
