Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Unplug the laptop from the power adapter and turn the power off. Failure to unplug laptop before proceeding could result in risk of electric shock! Failure to unplug laptop before proceeding could result in risk of electric shock!
  • Unplug the laptop from the power adapter and turn the power off.
  • Failure to unplug laptop before proceeding could result in risk of electric shock!
Aggiungi Commento
Slide the battery-lock tab and hold. Flip the battery away from the chassis to remove it. Flip the battery away from the chassis to remove it.
  • Slide the battery-lock tab and hold.
  • Flip the battery away from the chassis to remove it.
Aggiungi Commento
Press the tab on the outside face of the optical drive to release a handle. Pull the handle to eject the optical drive unit from the slot, and slide it out. Pull the handle to eject the optical drive unit from the slot, and slide it out.
  • Press the tab on the outside face of the optical drive to release a handle.
  • Pull the handle to eject the optical drive unit from the slot, and slide it out.
Aggiungi Commento
Conclusione
charlierefvem
Membro da: 11/01/2011
854 Reputazione
7 Guide realizzate
Cal Poly, Team 13-2, Forte Winter 2011 Membro di Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,065
