Introduzione
This guide requires a Phillips #00 screwdriver
Parti
Nessuna parte richiesta.
Unplug the laptop from the power adapter and turn the power off. Failure to unplug laptop before proceeding could result in risk of electric shock! Failure to unplug laptop before proceeding could result in risk of electric shock!
  • Unplug the laptop from the power adapter and turn the power off.
  • Failure to unplug laptop before proceeding could result in risk of electric shock!
Aggiungi Commento
Slide the battery-lock tab and hold. Flip the battery away from the chassis to remove it. Flip the battery away from the chassis to remove it.
  • Slide the battery-lock tab and hold.
  • Flip the battery away from the chassis to remove it.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Undo the screw on the Mini-PCI card cover labeled "C" This screw will remain within the panel
  • Undo the screw on the Mini-PCI card cover labeled "C"
  • This screw will remain within the panel
  • Remove the panel from the chassis.
Aggiungi Commento
Disconnect the antenna cables from the Mini-PCI card.
  • Disconnect the antenna cables from the Mini-PCI card.
Aggiungi Commento
Use your fingertips to carefully spread apart the white plastic tabs. Flip the Mini-PCI card up at a 45 degree angle. Remove the card from the computer by sliding out diagonally
  • Use your fingertips to carefully spread apart the white plastic tabs.
  • Flip the Mini-PCI card up at a 45 degree angle.
  • Remove the card from the computer by sliding out diagonally
  • Ground yourself while dealing with the card. Static shock can cause damage to the card. Store the card in anti-static bag when not in use.
Aggiungi Commento
Conclusione
charlierefvem
Membro da: 11/01/2011
854 Reputazione
7 Guide realizzate
Cal Poly, Team 13-2, Forte Winter 2011 Membro di Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 3,954
