Introduzione
This guide will help you replace the RAM (memory module) on your Dell Inspiron 9100. It is useful to replace the RAM if your computer runs slower than normal or if your programs constantly freeze.
This guide requires a Phillips #00 screwdriver.
Parti
Nessuna parte richiesta.
Unplug the laptop from the power adapter and turn the power off. Failure to unplug laptop before proceeding could result in risk of electric shock! Failure to unplug laptop before proceeding could result in risk of electric shock!
  • Unplug the laptop from the power adapter and turn the power off.
  • Failure to unplug laptop before proceeding could result in risk of electric shock!
Aggiungi Commento
Slide the battery-lock tab and hold. Flip the battery away from the chassis to remove it. Flip the battery away from the chassis to remove it.
  • Slide the battery-lock tab and hold.
  • Flip the battery away from the chassis to remove it.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Using the Philips #00 screwdriver, undo the screw on the memory module cover, labeled "M." This screw will remain in the panel.
  • Using the Philips #00 screwdriver, undo the screw on the memory module cover, labeled "M."
  • This screw will remain in the panel.
  • Pull the cover away from the laptop using your finger.
Aggiungi Commento
Use your fingertips to carefully spread apart the plastic white tabs. Flip the RAM up at a 45 degree angle and remove it. Hold the RAM by the edges only.
  • Use your fingertips to carefully spread apart the plastic white tabs.
  • Flip the RAM up at a 45 degree angle and remove it.
  • Hold the RAM by the edges only.
  • Ground yourself while dealing with RAM. Static shock can damage the memory. Store the RAM in an anti-static bag while it is not in use.
Aggiungi Commento
Repeat step four with the second RAM.
  • Repeat step four with the second RAM.
Aggiungi Commento
Conclusione
charlierefvem
Membro da: 11/01/2011
854 Reputazione
7 Guide realizzate
Cal Poly, Team 13-2, Forte Winter 2011 Membro di Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,156
