Introduzione
This guide requires a Phillips #00 screwdriver
Parti
Nessuna parte richiesta.
Unplug the laptop from the power adapter and turn the power off. Failure to unplug laptop before proceeding could result in risk of electric shock! Failure to unplug laptop before proceeding could result in risk of electric shock!
  • Unplug the laptop from the power adapter and turn the power off.
  • Failure to unplug laptop before proceeding could result in risk of electric shock!
Aggiungi Commento
Slide the battery-lock tab and hold. Flip the battery away from the chassis to remove it. Flip the battery away from the chassis to remove it.
  • Slide the battery-lock tab and hold.
  • Flip the battery away from the chassis to remove it.
Aggiungi Commento
Turn the laptop around.
  • Turn the laptop around.
Aggiungi Commento
Use your fingers to gently pull up on the hinge covers.  They will release with an audible snap. Fold the screen back to 180 degrees. Using your index fingers, pull up the hinge cover.
  • Use your fingers to gently pull up on the hinge covers. They will release with an audible snap.
  • Fold the screen back to 180 degrees.
  • Using your index fingers, pull up the hinge cover.
Aggiungi Commento
After the hinges pop, pull the hinge cover gently. Pull the clear tab on the right side of the laptop up.  This tab will disconnect the hinge cover from the laptop. Pull the clear tab on the right side of the laptop up.  This tab will disconnect the hinge cover from the laptop.
  • After the hinges pop, pull the hinge cover gently.
  • Pull the clear tab on the right side of the laptop up. This tab will disconnect the hinge cover from the laptop.
Aggiungi Commento
Remove the two 3mm screws on the top of the keyboard (nearest to the screen)
  • Remove the two 3mm screws on the top of the keyboard (nearest to the screen)
Aggiungi Commento
Tilt the keyboard away from the screen. Pull up on the white tab underneath the keyboard to release the keyboard. Pull up on the white tab underneath the keyboard to release the keyboard.
  • Tilt the keyboard away from the screen.
  • Pull up on the white tab underneath the keyboard to release the keyboard.
Aggiungi Commento
Conclusione
Ana
Membro da: 11/01/2011
111 Reputazione
1 Guida realizzata
Cal Poly, Team 13-2, Forte Winter 2011 Membro di Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 3,624
