Introduzione
This guide will teach you how to remove the keyboard on a Dell Inspiron 910.
Parti
Nessuna parte richiesta.
Remove the two countersunk keyboard screws using the Phillips #00 screwdriver
  • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver
  • Battery removal is not necessary for keyboard removal.
Aggiungi Commento
Lift up the keyboard using your fingers or a plastic opening tool
  • Lift up the keyboard using your fingers or a plastic opening tool
  • Do not not tear the ribbon cable hidden behind the keyboard
  • Disconnect the cable by sliding the connector ears outward
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Kyle Beekman
Membro da: 05/04/2012
141 Reputazione
6 Guide realizzate
Cal Poly, Team 14-10, Forte Spring 2012 Membro di Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 Membri
7 Guide realizzate
Impossible if you don’t have this tutorial.
2 Photos!
Perfect!
WildBill - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,452
