Introduzione
We will show you how to remove and replace the hinge cover which houses the power button.
Parti
Nessuna parte richiesta.
Remove the battery from the bottom of the laptop.
  • Remove the battery from the bottom of the laptop.
  • Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
  • It is important to remove the battery so that you will not be electrocuted while working with the computer's hardware.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Locate the small opening at the upper left of the top blue panel which houses the power button. Use a spudger to lift up and remove the blue panel. Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
  • Locate the small opening at the upper left of the top blue panel which houses the power button.
  • Use a spudger to lift up and remove the blue panel.
  • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
Aggiungi Commento
Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
  • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
  • You should now be able to completely remove the hinge cover.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Brian Murphy
Membro da: 13/04/2011
347 Reputazione
4 Guide realizzate
Cal Poly, Team 18-22, Garner Spring 2011 Membro di Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Membri
15 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,724
