Introduzione
You will need a Philips screwdriver, an anti-static wrist strap, and a wedge type tool such as a flat-head screwdriver. This guide will walk you through how to replace the LCD screen on your Dell Inspiron 600m.
Push in the tab on the battery and lift up. The battery should detach very easily. Push in the tab on the battery and lift up. The battery should detach very easily. Push in the tab on the battery and lift up. The battery should detach very easily.
  • Push in the tab on the battery and lift up. The battery should detach very easily.
Aggiungi Commento
Locate the rubber dots on the plastic around the lcd panel. Use your fingernails or a flat-head screwdriver to remove the rubber dots around the screen by pushing any direction on them.
  • Locate the rubber dots on the plastic around the lcd panel.
  • Use your fingernails or a flat-head screwdriver to remove the rubber dots around the screen by pushing any direction on them.
  • Underneath the rubber dots will be screws. Remove them with the #00 screwdriver.
Aggiungi Commento
After removing the screws under the rubber dots, use your plastic opening tool to un-clip the plastic around the screen. There are clips about every inch around the right, left, and top of the plastic. Be sure that all of them are unclipped.
  • After removing the screws under the rubber dots, use your plastic opening tool to un-clip the plastic around the screen.
  • There are clips about every inch around the right, left, and top of the plastic. Be sure that all of them are unclipped.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Lift the plastic around the screen off after it is un-clipped by pulling straight up on it.
  • Lift the plastic around the screen off after it is un-clipped by pulling straight up on it.
  • The bottom part of the plastic is a little sticky.
Aggiungi Commento
Underneath the plastic around the edge, there are 2 screws on each side. Remove them with a Philips #00 screwdriver.
  • Underneath the plastic around the edge, there are 2 screws on each side. Remove them with a Philips #00 screwdriver.
  • The middle screw does not need to be removed.
Aggiungi Commento
After all the screws around the edge have been removed, lift the LCD panel off of the base.
  • After all the screws around the edge have been removed, lift the LCD panel off of the base.
  • The LCD is still attached to the computer. Do not pull too hard or you could break the cable.
Aggiungi Commento
Flip the LCD panel over. Do not touch on or near the back of the panel where is says "Don't Touch". LCD panels contain mercury which is hazardous to humans. Remove the cable by squeezing each side of the connector and gently pulling straight out.
  • Flip the LCD panel over.
  • Do not touch on or near the back of the panel where is says "Don't Touch". LCD panels contain mercury which is hazardous to humans.
  • Remove the cable by squeezing each side of the connector and gently pulling straight out.
Aggiungi Commento
Remove the cable at the base of the laptop by pulling up on the tab attached to the cable. Remove the cable at the base of the laptop by pulling up on the tab attached to the cable. Remove the cable at the base of the laptop by pulling up on the tab attached to the cable.
  • Remove the cable at the base of the laptop by pulling up on the tab attached to the cable.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Alex Klimaj
Membro da: 01/04/2011
143 Reputazione
1 Guida realizzata
Cal Poly, Team 10-40, Forte Spring 2011 Membro di Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 6,265
