Salta al contenuto principale
Dell Inspiron 600m Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 600m Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Dell Inspiron 600m Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Dell Inspiron 600m Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m Keyboard Replacement, Keyboard: passo 2, immagine 1 di 1
    • Orient laptop with the keyboard facing upward and the lid open.
  3. Dell Inspiron 600m Keyboard Replacement: passo 3, immagine 1 di 3 Dell Inspiron 600m Keyboard Replacement: passo 3, immagine 2 di 3 Dell Inspiron 600m Keyboard Replacement: passo 3, immagine 3 di 3
    • Caution the face plate is a fragile piece of plastic. Handle carefully.
    • Start in the upper right corner and work to the left when removing the face plate (includes power button and volume controls).
    • Use a flathead screwdriver (or anything flat and strong) to wedge underneath the face plate.
    • Carefully lift the screwdriver to remove the face plate.
  4. Dell Inspiron 600m Keyboard Replacement: passo 4, immagine 1 di 3 Dell Inspiron 600m Keyboard Replacement: passo 4, immagine 2 di 3 Dell Inspiron 600m Keyboard Replacement: passo 4, immagine 3 di 3
    • Use a the Phillips screwdriver to remove the two screws.
  5. Dell Inspiron 600m Keyboard Replacement: passo 5, immagine 1 di 1
    • Gently slide keyboard toward screen.
    • Lift keyboard carefully. It is attached by a ribbon cable.
  6. Dell Inspiron 600m Keyboard Replacement: passo 6, immagine 1 di 3 Dell Inspiron 600m Keyboard Replacement: passo 6, immagine 2 di 3 Dell Inspiron 600m Keyboard Replacement: passo 6, immagine 3 di 3
    • Pull upward on blue tab to disconnect keyboard.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 10-40, Forte Spring 2011 Membro di Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,440
