Introduzione
Before removing the RAM you will need to remove your battery.
Push in the tab on the battery and lift up. The battery should detach very easily. Push in the tab on the battery and lift up. The battery should detach very easily. Push in the tab on the battery and lift up. The battery should detach very easily.
  • Push in the tab on the battery and lift up. The battery should detach very easily.
Aggiungi Commento
Remove the single screw securing the RAM compartment and pull up to reveal the RAM. Remove the single screw securing the RAM compartment and pull up to reveal the RAM. Remove the single screw securing the RAM compartment and pull up to reveal the RAM.
  • Remove the single screw securing the RAM compartment and pull up to reveal the RAM.
Aggiungi Commento
Push on the small white metal tabs on both sides of a module to unlock it. The RAM should be stick out at approximately a 45 degree angle. Grasp the RAM by the sides and pull straight out to remove it. If the RAM sticks slightly, wiggle it back and forth gently to loosen it.
  • Push on the small white metal tabs on both sides of a module to unlock it.
  • The RAM should be stick out at approximately a 45 degree angle. Grasp the RAM by the sides and pull straight out to remove it.
    • If the RAM sticks slightly, wiggle it back and forth gently to loosen it.
Aggiungi Commento
Conclusione
Taylor Woods
Membro da: 05/04/2011
101 Reputazione
3 Guide realizzate
Cal Poly, Team 10-40, Forte Spring 2011 Membro di Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,557
