Introduzione
Use this guide to replace the hard drive of the Dell Inspiron 530.
Parti
Nessuna parte richiesta.
Place the case on its side.
  • Place the case on its side.
  • Locate and remove the two 13.1 mm thumbscrews.
Aggiungi Commento
Slide the side panel towards the back and remove.
  • Slide the side panel towards the back and remove.
Aggiungi Commento
Locate the hard drive.
  • Locate the hard drive.
Aggiungi Commento
Disconnect the two cables from the back of the hard drive.
  • Disconnect the two cables from the back of the hard drive.
Aggiungi Commento
Locate and remove the four 7.8 mm screws with a Phillips #0 screwdriver.
  • Locate and remove the four 7.8 mm screws with a Phillips #0 screwdriver.
  • Pull the hard drive out towards the back of computer.
Aggiungi Commento
Conclusione
Altre 11 persone hanno completato questa guida.
James Aldag
Membro da: 20/10/2011
327 Reputazione
8 Guide realizzate
Cal Poly, Team 6-8, Regan Fall 2011 Membro di Cal Poly, Team 6-8, Regan Fall 2011
CPSU-REGAN-F11S6G8
4 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 67
Tutti i Tempi: 15,280
