Introduzione
This guide is useful for replacing a damaged or malfunctioning screen.
Unplug the laptop before changing the battery to avoid electric shock. Place the laptop on a flat stable surface.
  • Unplug the laptop before changing the battery to avoid electric shock.
  • Place the laptop on a flat stable surface.
  • Flip the laptop over so the underside is visible.
Aggiungi Commento
Locate the battery lock switch. Slide the lock switch to the left (away from the lock symbol).
  • Locate the battery lock switch.
  • Slide the lock switch to the left (away from the lock symbol).
  • Slide the battery out away from the laptop.
Aggiungi Commento
Separate the screws by size and head type.  Be sure to keep them in a safe place.
  • Separate the screws by size and head type. Be sure to keep them in a safe place.
  • Remove the sixteen 2mm Phillips #00 screws from the bottom of the laptop.
  • Remove the two 2mm Phillips #0 screws from the hard drive port.
Aggiungi Commento
Keep your hand pressed firmly on the back panel to prevent it from falling. Flip the laptop over horizontally and open up the lid. Insert the tip of the plastic opening tool into the upper left corner of the panel.
  • Keep your hand pressed firmly on the back panel to prevent it from falling.
  • Flip the laptop over horizontally and open up the lid.
  • Insert the tip of the plastic opening tool into the upper left corner of the panel.
  • Keeping its tip under the top panel, slide the plastic opening tool around the panel until the panel is completely loose. Next gently remove the panel.
  • Remove the four 2mm Phillips #0 screws at the top of the keyboard.
  • Slide the plastic opening tool around the keyboard until the keyboard is completely loose. Gently remove the keyboard.
Aggiungi Commento
Do not lift the keyboard completely free to avoid damaging its connections to the laptop interior. Locate the small black latch attached to blue tape. Lift the small latch with your finger and pull the blue tape from its port.
  • Do not lift the keyboard completely free to avoid damaging its connections to the laptop interior.
  • Locate the small black latch attached to blue tape.
  • Lift the small latch with your finger and pull the blue tape from its port.
  • Slide the keyboard away from the mousepad and set it aside.
Aggiungi Commento
Always pull wires from their plastic ends, not their cables, to avoid wire damage. Locate the three wires in the top left corner of the metal panel. Use the spudger to push the two cables out of their ports.
  • Always pull wires from their plastic ends, not their cables, to avoid wire damage.
  • Locate the three wires in the top left corner of the metal panel.
  • Use the spudger to push the two cables out of their ports.
  • Pull the blue tab directly up to remove middle wire.
Aggiungi Commento
Remove the three 1mm Phillips #00 screws on the metal plate. Lift the black cover and slide the blue tab away from the cover.
  • Remove the three 1mm Phillips #00 screws on the metal plate.
  • Lift the black cover and slide the blue tab away from the cover.
Aggiungi Commento
Always pull wires from their plastic ends, not their cables, to avoid wire damage. Gently remove the three grey wires from the metal tabs. Insert the tip of the plastic opening tool into the bottom left corner of the panel.
  • Gently remove the three grey wires from the metal tabs.
  • Insert the tip of the plastic opening tool into the bottom left corner of the panel.
  • Gently lift off the top metal panel.
Aggiungi Commento
Use the spudger to lift the wires from their connections. Remember to pull wires from their plastic ends, not their cables, to avoid wire damage. Flip the laptop over and pull the connections through until they are free  from the laptop interior.
  • Use the spudger to lift the wires from their connections.
  • Remember to pull wires from their plastic ends, not their cables, to avoid wire damage.
  • Flip the laptop over and pull the connections through until they are free from the laptop interior.
Aggiungi Commento
Remove the two 2mm  Phillips #0 screws from the screen hinges. Lift the screen away from the laptop and gently set it down.
  • Remove the two 2mm Phillips #0 screws from the screen hinges.
  • Lift the screen away from the laptop and gently set it down.
  • Put the rest of the laptop aside.
Aggiungi Commento
Use the plastic opening tool to remove the plastic cover from the screen. Remove the eight 2mm Phillips #0 screws from the corners of the screen. Lift the screen away from the back panel.
  • Use the plastic opening tool to remove the plastic cover from the screen.
  • Remove the eight 2mm Phillips #0 screws from the corners of the screen.
  • Lift the screen away from the back panel.
Aggiungi Commento
Remove the four 2mm Phillips #0 screws from the sides of the screen. Remove the side railings from both sides of the screen by pulling the railings gently away from the screen.
  • Remove the four 2mm Phillips #0 screws from the sides of the screen.
  • Remove the side railings from both sides of the screen by pulling the railings gently away from the screen.
Aggiungi Commento
Conclusione
Tina Rickard
Membro da: 07/04/2014
701 Reputazione
5 Guide realizzate
Cal Poly, Team 6-3, Forte Spring 2014 Membro di Cal Poly, Team 6-3, Forte Spring 2014
CPSU-FORTE-S14S6G3
5 Membri
7 Guide realizzate
Succeed ! Thanks.
Note: @ First opening, I add to do step 9 before the step 8. The antenna wire prevent you to "Gently lift off the top metal panel".
wxadha - Replica
My screen almost always has a pink spotty look. How do I know if I need to replace the screen, or just the wires?
Kathleen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 42
Tutti i Tempi: 2,635
