Introduzione
Follow this guide if your disk drive is damaged and needs replacement.
Parti
Nessuna parte richiesta.
Unplug the laptop before changing the battery to avoid electric shock. Place the laptop on a flat stable surface.
  • Unplug the laptop before changing the battery to avoid electric shock.
  • Place the laptop on a flat stable surface.
  • Flip the laptop over so the underside is visible.
Aggiungi Commento
Locate the battery lock switch. Slide the lock switch to the left (away from the lock symbol).
  • Locate the battery lock switch.
  • Slide the lock switch to the left (away from the lock symbol).
  • Slide the battery out away from the laptop.
Aggiungi Commento
Remove the 2mm Phillips #00 screw next to the module cover. Pull the disc drive away from the laptop.
  • Remove the 2mm Phillips #00 screw next to the module cover.
  • Pull the disc drive away from the laptop.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Tina Rickard
Membro da: 07/04/2014
686 Reputazione
5 Guide realizzate
Cal Poly, Team 6-3, Forte Spring 2014 Membro di Cal Poly, Team 6-3, Forte Spring 2014
CPSU-FORTE-S14S6G3
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 622
