Salta al contenuto principale
Dell Inspiron 17-5749 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 17-5749 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 17-5749 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Keyboard Replacement: passo 2, immagine 1 di 2 Dell Inspiron 17-5749 Keyboard Replacement: passo 2, immagine 2 di 2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 3 Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 3 Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: passo 3, immagine 3 di 3
    • Turn the computer over and open the display as far as possible
    • Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
    • Before turning over the keyboard, be careful not to pull the keyboard too far away as it could damage the connected ribbon cables.
  4. Dell Inspiron 17-5749 Keyboard Replacement: passo 4, immagine 1 di 1
    • Carefully turn the keyboard over and place it on the palm rest assembly.
    • Lift the latches and disconnect the keyboard cable and keyboard back-light cable from the system board.
    • Lift the keyboard along with the cables, off the palm-rest assembly and set it aside.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 422
