Salta al contenuto principale
Dell Inspiron 17-5748 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 17-5748 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop upside down.
    • Locate the battery lock latches.
  2. Dell Inspiron 17-5748 Keyboard Replacement: passo 2, immagine 1 di 1
    • Slide both lock latches to the unlocked position.
  3. Dell Inspiron 17-5748 Keyboard Replacement: passo 3, immagine 1 di 1
    • Lift the battery up and out of the laptop battery socket.
  4. Dell Inspiron 17-5748 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 1
    • Open the laptop and locate the keyboard.
  5. Dell Inspiron 17-5748 Keyboard Replacement: passo 5, immagine 1 di 2 Dell Inspiron 17-5748 Keyboard Replacement: passo 5, immagine 2 di 2
    • Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
    • Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
  6. Dell Inspiron 17-5748 Keyboard Replacement: passo 6, immagine 1 di 2 Dell Inspiron 17-5748 Keyboard Replacement: passo 6, immagine 2 di 2
    • Do not remove the keyboard completely. The ribbon cable underneath, attaching it to the motherboard, must still be detached.
    • Lift the keyboard partially and flip it over.
  7. Dell Inspiron 17-5748 Keyboard Replacement: passo 7, immagine 1 di 2 Dell Inspiron 17-5748 Keyboard Replacement: passo 7, immagine 2 di 2
    • Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
    • Gently detach the cable and the keyboard from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 641
