Introduzione
There are many parts that can go bad within a display. This guide does not necessarily cover the replacement of all the smaller pieces, but it does allow you to access those parts.
Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
  • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
  • Turn the laptop over to its back.
Aggiungi Commento
Slide the release latch while simultaneously pulling backwards on the battery.
  • Slide the release latch while simultaneously pulling backwards on the battery.
Aggiungi Commento
Slide the battery out of the battery bay.
  • Slide the battery out of the battery bay.
Aggiungi Commento
After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
Aggiungi Commento
Flip the laptop over to the front and open the display as far as possible.
  • Flip the laptop over to the front and open the display as far as possible.
Aggiungi Commento
The Center Control Cover is VERY fragile,  be careful when using prying tools. Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here. Carefully lift the Center Control Cover away from the laptop.
  • The Center Control Cover is VERY fragile, be careful when using prying tools.
  • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
  • Carefully lift the Center Control Cover away from the laptop.
Aggiungi Commento
Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
Aggiungi Commento
Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
  • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
  • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
Aggiungi Commento
Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
  • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
The connector latch is the black piece.
Maurice Volaski - Replica
Lift the keyboard up and away from the laptop.
  • Lift the keyboard up and away from the laptop.
Aggiungi Commento
Remove the two screws (5.5mm, Phillips #1) from the laptop base.
  • Remove the two screws (5.5mm, Phillips #1) from the laptop base.
Uh, how did the back cover end up coming off?
Remove black and white wires from the WLAN that lead to the display by pulling straight up.
  • Remove black and white wires from the WLAN that lead to the display by pulling straight up.
  • Unwind the wires so they can be freely pulled through in the next step.
Aggiungi Commento
Turn the laptop over to its standard position.
  • Turn the laptop over to its standard position.
  • Disconnect the Wed cable and Camera1 cable from the respective Motherboard connectors as marked. Unsecure the wires so they are loose.
  • Pull the black and white wires previously connected to the WLAN through the hole.
Aggiungi Commento
Remove the Camera1 cable, the Wed cable, and the black and white wires from the routing guides.
  • Remove the Camera1 cable, the Wed cable, and the black and white wires from the routing guides.
  • Remove the four screws (5mm Phillips #1) (two on either side) that secure the display assembly.
Aggiungi Commento
Lift the display assembly off the computer.
  • Lift the display assembly off the computer.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Nathan Lemay
Membro da: 16/04/2014
2.503 Reputazione
15 Guide realizzate
Cal Poly, Team 9-14, Regan Spring 2014 Membro di Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Membri
15 Guide realizzate
wow that is really good
Mck - Isolutions - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 61
Tutti i Tempi: 2,912
