Introduzione
This guide will serve as a prerequisite for more advanced replacement guides, this base cover will rarely actually need to be replaced in it of itself.
Parti
Nessuna parte richiesta.
Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
  • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
  • Turn the laptop over to its back.
Aggiungi Commento
Slide the release latch while simultaneously pulling backwards on the battery.
  • Slide the release latch while simultaneously pulling backwards on the battery.
Aggiungi Commento
Slide the battery out of the battery bay.
  • Slide the battery out of the battery bay.
Aggiungi Commento
Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
  • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
  • The screws are connected to the base cover by a washer anddo not remove from the base cover.
Aggiungi Commento
Carefully lift the base cover vertically away from the laptop. Carefully lift the base cover vertically away from the laptop.
  • Carefully lift the base cover vertically away from the laptop.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Nathan Lemay
Membro da: 16/04/2014
2.491 Reputazione
15 Guide realizzate
Cal Poly, Team 9-14, Regan Spring 2014 Membro di Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Membri
15 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,249
