Introduzione
Use this guide to help you replace the RAM in a Dell Inspiron 1525.
Cosa ti serve
Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
The screws may only need to be loosened, as they are generally retained by plastic washers.
Remove the bottom panel.
Push the white tabs on either side of the RAM chip outward. The chip should pop up a little.
Carefully remove the RAM chip by pulling it out at a slight vertical angle.
Altre 5 persone hanno completato questa guida.
