Introduzione
In this guide we will be showing you how to replace the battery on your Dell Inspiron 1525. You don't need any tools for this process.
Flip the computer upside down and locate the battery release switch.
  • Flip the computer upside down and locate the battery release switch.
  • Remember to disconnect any and all power sources when working on any electronic device to prevent damage.
Aggiungi Commento
Slide and hold the switch away from the lock symbol to release the battery lock.
  • Slide and hold the switch away from the lock symbol to release the battery lock.
Aggiungi Commento
Grip the battery and gently pull it away from the rest of the device. You can now let go of the battery release switch and let it return to its original position.
  • Grip the battery and gently pull it away from the rest of the device. You can now let go of the battery release switch and let it return to its original position.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Phil Hopkins
Membro da: 18/04/2010
308 Reputazione
1 Guida realizzata
Cal Poly, Team 23-101, Johann Spring 2010 Membro di Cal Poly, Team 23-101, Johann Spring 2010
CPSU-JOHANN-S10S23G101
2 Membri
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 4,452
