Introduzione
This guide will show how to access your DVD drive.
Parti
Nessuna parte richiesta.
Rotate the laptop so its bottom is facing up.
  • Rotate the laptop so its bottom is facing up.
Aggiungi Commento
Identify the lock mechanisms holding the battery in place. Slide each button outward with your fingers to disengage the battery. Pull the battery off with your hand to separate it from the laptop.
  • Identify the lock mechanisms holding the battery in place.
  • Slide each button outward with your fingers to disengage the battery.
  • Pull the battery off with your hand to separate it from the laptop.
Aggiungi Commento
Locate the 4 mm Phillips #1 screw next to the white padlock image that holds the DVD drive in place. Remove this screw with a Phillips #1 screwdriver.
  • Locate the 4 mm Phillips #1 screw next to the white padlock image that holds the DVD drive in place.
  • Remove this screw with a Phillips #1 screwdriver.
Aggiungi Commento
Use a plastic opener tool to carefully pry the DVD drive out of its pocket on the side of the laptop. Once sticking out, pull the DVD drive the rest of the way out with your hand. Once sticking out, pull the DVD drive the rest of the way out with your hand.
  • Use a plastic opener tool to carefully pry the DVD drive out of its pocket on the side of the laptop.
  • Once sticking out, pull the DVD drive the rest of the way out with your hand.
Aggiungi Commento
Conclusione
Rogelio Ordonez
Membro da: 26/09/2012
54 Reputazione
2 Guide realizzate
Cal Poly, Team 15-47, Forte Fall 2012 Membro di Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 802
