Introduzione
This guide will show you how to remove and replace the battery in your laptop.
Rotate the laptop so its bottom is facing up.
  • Rotate the laptop so its bottom is facing up.
Aggiungi Commento
Identify the lock mechanisms holding the battery in place. Slide each button outward with your fingers to disengage the battery. Pull the battery off with your hand to separate it from the laptop.
  • Identify the lock mechanisms holding the battery in place.
  • Slide each button outward with your fingers to disengage the battery.
  • Pull the battery off with your hand to separate it from the laptop.
Aggiungi Commento
Conclusione
Nikolaus Powell
Membro da: 20/09/2012
414 Reputazione
3 Guide realizzate
Cal Poly, Team 15-47, Forte Fall 2012 Membro di Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,186
