Salta al contenuto principale
Dell Inspiron 15-7559 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
    • After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
  2. Dell Inspiron 15-7559 Keyboard Replacement: passo 2, immagine 1 di 2 Dell Inspiron 15-7559 Keyboard Replacement: passo 2, immagine 2 di 2
    • Now lift the keyboard enough to access the ribbon cables beneath it.
  3. Dell Inspiron 15-7559 Keyboard Replacement: passo 3, immagine 1 di 3 Dell Inspiron 15-7559 Keyboard Replacement: passo 3, immagine 2 di 3 Dell Inspiron 15-7559 Keyboard Replacement: passo 3, immagine 3 di 3
    • For the two ribbon cables connecting the keyboard to the laptop, use your finger to lift the latch up.
    • Once the latch is raised, lift the ribbon cable up and out of the latch.
  4. Dell Inspiron 15-7559 Keyboard Replacement: passo 4, immagine 1 di 1
    • Now that the keyboard has been fully disconnected from the laptop, lift it off of the device.
Conclusione
Altre 8 persone hanno completato questa guida.
UW Tacoma, Team S3-G2, Liner Fall 2017 Membro di UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
5 Membri
9 Guide realizzate
2 Commenti
How to put it back
Using Name - Replica
Do the steps in reverse order, like it says at the end of the tutorial
Arthur Alford -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 41
Tutti i Tempi: 6,858
