Salta al contenuto principale
Dell Inspiron 15-7537 Wireless Card Replacement
Cosa ti serve
  1. Dell Inspiron 15-7537 Wireless Card Replacement, Bottom Case: passo 1, immagine 1 di 1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Wireless Card Replacement: passo 2, immagine 1 di 1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Wireless Card Replacement: passo 3, immagine 1 di 1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: passo 4, immagine 1 di 2 Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: passo 4, immagine 2 di 2
    • Completely unscrew the 2 mm screw that connects the WiFi card to the mother board using a Philips head screwdriver.
  5. Dell Inspiron 15-7537 Wireless Card Replacement: passo 5, immagine 1 di 1
    • Disconnect the two antennas (one black and one white) from the wireless card.
  6. Dell Inspiron 15-7537 Wireless Card Replacement: passo 6, immagine 1 di 1
    • Remove the WiFi card.
    • To place a new WiFi card, connect the antenna cables to the WiFi card. The white cable goes to the white triangle, and the black cable goes to the black triangle.
    • Avoid damaging the card by not placing any cables underneath the card.
Linea Traguardo
Cal Poly, Team 18-2, Maness Winter 2015 Membro di Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 3,635
