Introduzione
Use this guide to replace you USB board if you have determined that it is no longer working.
Cosa ti serve
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
The model device did not come with a hard drive. However, you will need to remove the hard drive to proceed. Please remove the hard drive following the steps on page 16 of the official Dell Inspiron 15-7537 manual.
Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
Unscrew the two black 5 mm screws underneath the keyboard using a Phillips head screwdriver.
