Introduzione
Use this guide to replace the RAM if you would like to upgrade the RAM, or replace it if there is damage.
Cosa ti serve
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Gently pull apart clips on the ends of the memory module until the memory module pops up.
Altre 2 persone hanno completato questa guida.
