Introduzione
Use this guide to replace the keyboard if you have determined your keyboard issues may be resolved by replacing the keyboard.
Cosa ti serve
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
Altre 11 persone hanno completato questa guida.
3 Commenti
Thanks It’s Useful
It is important to note that the little black clips on the ends of the keyboard wires SWIVEL UP! I broke mine because nothing in this guide told me how to get the wires out properly.
