Salta al contenuto principale
Dell Inspiron 15-5567 Battery Replacement
Cosa ti serve
  1. Dell Inspiron 15-5567 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Power off the laptop and wait 20 minutes before beginning disassembly.
    • Use a Phillips #0 screwdriver to remove 15 screws from the bottom of the laptop.
  2. Dell Inspiron 15-5567 Battery Replacement: passo 2, immagine 1 di 3 Dell Inspiron 15-5567 Battery Replacement: passo 2, immagine 2 di 3 Dell Inspiron 15-5567 Battery Replacement: passo 2, immagine 3 di 3
    • Slide the DVD drive out of the laptop.
    • Remove the three screws underneath using a micro screwdriver.
    • Pry off the back cover of the laptop using an opening tool.
  3. Dell Inspiron 15-5567 Battery Replacement: passo 3, immagine 1 di 2 Dell Inspiron 15-5567 Battery Replacement: passo 3, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the two screws attached to the metal bracket holding down the battery.
    • Remove the screw attached to the laptop battery using a Phillips #0 screwdriver.
  4. Dell Inspiron 15-5567 Battery Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15-5567 Battery Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery connecting cable from the laptop by sliding it out.
    • Confirm the new battery is correct for this laptop model by looking at the battery type and power.
  5. Dell Inspiron 15-5567 Battery Replacement: passo 5, immagine 1 di 2 Dell Inspiron 15-5567 Battery Replacement: passo 5, immagine 2 di 2
    • Attach the cable for the new battery to the laptop by sliding the cable into the port.
Conclusione
Altre 5 persone hanno completato questa guida.
Un commento
This battery did not come with the new cable. I had to reuse the old cable, which was very difficult to do.
Kat Vinson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 108
Tutti i Tempi: 7,416
