Introduzione
This replacement guide will explain how to insert a new memory card into the Dell Inspiron 15-3521 laptop. Keep in mind that to perform this replacement, you will be opening the interior of your device, so it is best to perform this replacement in a clean environment.
We are removing the battery to avoid the possibility of an electrical discharge when working with this system. Flip the laptop over. Slide the latches toward the outside of the laptop to unlock the battery.
  • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
  • Flip the laptop over.
  • Slide the latches toward the outside of the laptop to unlock the battery.
  • Lift the battery out of the laptop.
Aggiungi Commento
Loosen the two screws attaching the access door to the laptop body Using a spudger, pry open the access door  from the laptop Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  • Loosen the two screws attaching the access door to the laptop body
  • Using a spudger, pry open the access door from the laptop
  • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
Aggiungi Commento
To access the memory cards, push out the latches on the left and right of the memory cards To remove the memory card, pull it out of the tray with the latches still stretched out Insert a new memory card in to the memory card tray, depressing until side latches engage with a click.
  • To access the memory cards, push out the latches on the left and right of the memory cards
  • To remove the memory card, pull it out of the tray with the latches still stretched out
  • Insert a new memory card in to the memory card tray, depressing until side latches engage with a click.
Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Andrew Dippre
Membro da: 13/10/2014
2.233 Reputazione
7 Guide realizzate
Clemson, Team 3-1, Benson Fall 2014 Membro di Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 57
Tutti i Tempi: 3,481
