Salta al contenuto principale
Dell Inspiron 15 7560 Fan Replacement
Cosa ti serve
  1. Dell Inspiron 15 7560 Fan Replacement, Fan: passo 1, immagine 1 di 1
    • Power off the laptop.
    • Place the laptop with the bottom facing upwards.
    • Remove eight 5 mm screws from the bottom of the laptop.
    • Loosen the three captive screws.
    • Use an iFixit opening tool to pry the bottom cover away from the laptop.
  2. Dell Inspiron 15 7560 Fan Replacement: passo 2, immagine 1 di 1
    • Remove the two screws from the fan.
  3. Dell Inspiron 15 7560 Fan Replacement: passo 3, immagine 1 di 2 Dell Inspiron 15 7560 Fan Replacement: passo 3, immagine 2 di 2
    • Remove the black insulating tape from the fan connector.
    • Pinch the sides of the white fan connector with your thumb and index fingernail and pull it out of its socket.
    • Remove the fan from the laptop.
    • Save the insulating tape for reinstallation.
  4. Dell Inspiron 15 7560 Fan Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15 7560 Fan Replacement: passo 4, immagine 2 di 2
    • Place the new fan in the laptop.
    • Plug the cable connector into its socket on the motherboard.
    • Replace the two screws around the fan.
  5. Dell Inspiron 15 7560 Fan Replacement: passo 5, immagine 1 di 1
    • Before replacing the bottom cover, start the computer to check if the cooling fan is installed successfully.
  6. Dell Inspiron 15 7560 Fan Replacement: passo 6, immagine 1 di 1
    • Power down the computer.
    • Reassemble the bottom cover.
Linea Traguardo
Kristen Gismondi
Membro da: 11/12/14
82.723 Reputazione
202 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.442 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 32
Tutti i Tempi: 695
