Introduzione
Use this guide to replace the RAM in your Dell Dimension 4600.
Strumenti
Nessun attrezzo richiesto.
Parti
Locate the case cover latch on the back of the computer.
  • Locate the case cover latch on the back of the computer.
Aggiungi Commento
Using your index finger, slide and hold the cover latch down.
  • Using your index finger, slide and hold the cover latch down.
  • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
Aggiungi Commento
Guida ai regali per la festa del papà
Facciamo onore non solo ai nostri padri — festeggiamo tutti i mentori che ci hanno insegnato a riparare.
Facciamo onore a chi ci ha insegnato a riparare.
Grab the edge of the panel and slide it away from the case until it is removed.
  • Grab the edge of the panel and slide it away from the case until it is removed.
Aggiungi Commento
Lay the computer flat on its side so that you are looking down on all of the components.
  • Lay the computer flat on its side so that you are looking down on all of the components.
  • Locate the RAM modules on the motherboard.
Aggiungi Commento
Locate the white or black tabs holding the RAM module in place. Place your index finger on the tab and firmly press down. The tab should release and the RAM module should be slightly raised.
  • Locate the white or black tabs holding the RAM module in place.
  • Place your index finger on the tab and firmly press down. The tab should release and the RAM module should be slightly raised.
  • Repeat this for the tab on the other side of the RAM module.
  • Repeat this step for each RAM module.
Aggiungi Commento
Grasp the RAM module and firmly pull upwards until it is released from its slot. Repeat this step for each RAM module.
  • Grasp the RAM module and firmly pull upwards until it is released from its slot.
Aggiungi Commento
Conclusione
Altre 12 persone hanno completato questa guida.
Cal Poly, Team 6-10, Regan Fall 2011 Membro di Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Membri
6 Guide realizzate
Would be great if the DIMM slots were explained (numbering) as to which are populated for dual channel, etc.
MJfromMD - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 23
Tutti i Tempi: 9,014
