Salta al contenuto principale
Dell Chromebook 13-7310 IO Board Replacement
Cosa ti serve
  1. Dell Chromebook 13-7310 IO Board Replacement, Back Cover: passo 1, immagine 1 di 2 Dell Chromebook 13-7310 IO Board Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 IO Board Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 IO Board Replacement, Battery: passo 3, immagine 1 di 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 IO Board Replacement: passo 4, immagine 1 di 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 IO Board Replacement: passo 5, immagine 1 di 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 IO Board Replacement, IO Board: passo 6, immagine 1 di 1
    • Remove the single 2mm screw securing the IO board to the laptop.
  7. Dell Chromebook 13-7310 IO Board Replacement: passo 7, immagine 1 di 1
    • Pull up on the connector to release the IO board cable from the motherboard.
    • It may be easier to pull from the blue tab.
  8. Dell Chromebook 13-7310 IO Board Replacement: passo 8, immagine 1 di 1
    • Remove the IO board.
Conclusione
Damon
Membro da: 11/01/18
181 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 323
