Salta al contenuto principale
DeWalt D28110 Power Switch Replacement
Cosa ti serve
  1. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Gear Case: passo 1, immagine 1 di 1
    • Using the T-15 screwdriver, remove the four 22-mm torx screws on the gear case.
    • Unplug the grinder before any disassembly.
  2. DeWalt D28110 Power Switch Replacement: passo 2, immagine 1 di 2 DeWalt D28110 Power Switch Replacement: passo 2, immagine 2 di 2
    • Pull out the gear case.
  3. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Back Panel Disassembly: passo 3, immagine 1 di 1
    • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
  4. DeWalt D28110 Power Switch Replacement: passo 4, immagine 1 di 1
    • Use the edge of the spudger to loosen and remove the back panel.
  5. DeWalt D28110 Power Switch Replacement: passo 5, immagine 1 di 1
    • Remove the single 20-mm torx screw holding the rear panel in place.
  6. DeWalt D28110 Power Switch Replacement: passo 6, immagine 1 di 1
    • Pull back the rear side of the back panel.
  7. DeWalt D28110 Power Switch Replacement, Power Switch: passo 7, immagine 1 di 3 DeWalt D28110 Power Switch Replacement, Power Switch: passo 7, immagine 2 di 3 DeWalt D28110 Power Switch Replacement, Power Switch: passo 7, immagine 3 di 3
    • There is an inner plastic guard behind the motor shaft.
    • Unscrew the four screws at each corner.
    • The guard should pull out with a good firm tug.
  8. DeWalt D28110 Power Switch Replacement: passo 8, immagine 1 di 3 DeWalt D28110 Power Switch Replacement: passo 8, immagine 2 di 3 DeWalt D28110 Power Switch Replacement: passo 8, immagine 3 di 3
    • Just behind the inner guard is the button slide.
    • Use needle nose pliers to pinch and push the button's flanges together, and out of the slot.
  9. DeWalt D28110 Power Switch Replacement: passo 9, immagine 1 di 3 DeWalt D28110 Power Switch Replacement: passo 9, immagine 2 di 3 DeWalt D28110 Power Switch Replacement: passo 9, immagine 3 di 3
    • Using the J-1 screwdriver, unscrew the power cord wires from the red switch box (located in the back of the grinder).
  10. DeWalt D28110 Power Switch Replacement: passo 10, immagine 1 di 2 DeWalt D28110 Power Switch Replacement: passo 10, immagine 2 di 2
    • Disconnect the motor wires from the other side of the switch box.
    • They wires are connected as a sleeve to the flat pin out of the switch box. A firm pull should do it.
Conclusione
Altre 3 persone hanno completato questa guida.
Kean Wee
Membro da: 01/22/15
495 Reputazione
4 Guide realizzate
Cal Poly, Team 18-6, Maness Winter 2015 Membro di Cal Poly, Team 18-6, Maness Winter 2015
CPSU-MANESS-W15S18G6
5 Membri
7 Guide realizzate
Un commento
Very clear and concise guide with relevent pictures. Very well done, thank you
Michael Creel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 45
Tutti i Tempi: 5,636
