Introduzione
Use this guide to disassemble your drill for cleaning, troubleshooting, or other maintenance.
Remove the seven T20 screws. Use the T-handle configuration of the screwdriver for the necessary force to loosen the screws.
  • Remove the seven T20 screws.
  • Use the T-handle configuration of the screwdriver for the necessary force to loosen the screws.
    • This drill required some cleaning to access the heads of the screws.
Aggiungi Commento
Wiggle the power supply cord to loosen the clamshell set and rotate the case open. Remove the bubble level.
  • Wiggle the power supply cord to loosen the clamshell set and rotate the case open.
  • Remove the bubble level.
Aggiungi Commento
Disengage and remove the spindle and gear assembly. Lift out the field assembly and armature.
  • Disengage and remove the spindle and gear assembly.
  • Lift out the field assembly and armature.
Aggiungi Commento
Slide the armature out of the field assembly. Rotate the field assembly to lay on the top. This allows for easier access to the frayed wire. Rotate the field assembly to lay on the top. This allows for easier access to the frayed wire.
  • Slide the armature out of the field assembly.
  • Rotate the field assembly to lay on the top. This allows for easier access to the frayed wire.
Aggiungi Commento
Cut a piece of electrical tape about one inch long. Wrap it tightly around the frayed section of the wiring. It is easier to start with one of the corners and wrap the tape at an angle.
  • Cut a piece of electrical tape about one inch long.
  • Wrap it tightly around the frayed section of the wiring.
  • It is easier to start with one of the corners and wrap the tape at an angle.
Aggiungi Commento
Lay the field assembly back down and align the armature. Reinsert the armature and rotate to point it "drill downward."
  • Lay the field assembly back down and align the armature.
  • Reinsert the armature and rotate to point it "drill downward."
Aggiungi Commento
Compress the brushes in the brush ring so the ball bearing at the end of the armature assembly can get through. Use a spudger or similar thin tool. Side view. This is not far enough.
  • Compress the brushes in the brush ring so the ball bearing at the end of the armature assembly can get through.
  • Use a spudger or similar thin tool.
    • Side view. This is not far enough.
Aggiungi Commento
Reaching from the sides, use the spudger to insert the armature even farther. Side view. This is far enough.
  • Reaching from the sides, use the spudger to insert the armature even farther.
  • Side view. This is far enough.
Aggiungi Commento
Lay the field/armature assembly down.
  • Lay the field/armature assembly down.
  • Place the ball bearing ring on the opposite end of the armature.
Aggiungi Commento
Place the motor back into the bottom half of the clamshell case.
  • Place the motor back into the bottom half of the clamshell case.
  • Make sure the three ball bearings are aligned with their receptors. Slightly adjusting the armature inside the field may be necessary.
Aggiungi Commento
Replace the spindle and gear assembly.
  • Replace the spindle and gear assembly.
  • Lift and adjust until the two helical gears are meshed properly.
Aggiungi Commento
Place the switch into the slot.
  • Place the switch into the slot.
  • Tuck the wiring both inside the edge of the case and out of the way of the support pegs.
Aggiungi Commento
Thread the power cord through the support pegs.
  • Thread the power cord through the support pegs.
  • Insert the top end of the cord protector into the slot.
Aggiungi Commento
Replace the level.
  • Replace the level.
Aggiungi Commento
Using the notch, align the two halves of the clamshell case and close it.
  • Using the notch, align the two halves of the clamshell case and close it.
  • Pay special attention to ensure the wiring all stays clear of the support pegs and the ball bearing wheels and level all stay in their slots.
Aggiungi Commento
Rescrew all seven screws using the T20 driver.
  • Rescrew all seven screws using the T20 driver.
  • To ensure a tight fit, use the T-handle configuration on the screwdriver.
Aggiungi Commento
Finished.
  • Finished.
Aggiungi Commento
Conclusione
Plug it in and see if it works more reliably.
Joanna
Membro da: 01/06/2014
149 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,505
