Salta al contenuto principale
Daewoo DWC LDC1412S Water pump replacement Replacement
Cosa ti serve
  1. Daewoo DWC LDC1412S Water pump replacement Replacement, Water pump replacement: passo 1, immagine 1 di 1
    • Turn the washing machine on it s back
  2. Daewoo DWC LDC1412S Water pump replacement Replacement: passo 2, immagine 1 di 2 Daewoo DWC LDC1412S Water pump replacement Replacement: passo 2, immagine 2 di 2
    • Unscrew the 2 screw that keep the pump in place
    • You can now gently tear down the pump
  3. Daewoo DWC LDC1412S Water pump replacement Replacement: passo 3, immagine 1 di 1
    • Compare your actual pump with the spare you found BEFORE dismounting pipes !
    • Seems ok ? Let s go forward !
  4. Daewoo DWC LDC1412S Water pump replacement Replacement: passo 4, immagine 1 di 2 Daewoo DWC LDC1412S Water pump replacement Replacement: passo 4, immagine 2 di 2
    • Dismount pipes by pressing steel rings and moving then out of range of the pump
    • Do this for all pipes connected on the pump
  5. Daewoo DWC LDC1412S Water pump replacement Replacement: passo 5, immagine 1 di 1
    • Pipes are now disconnected. Let's go for electrical connections
  6. Daewoo DWC LDC1412S Water pump replacement Replacement: passo 6, immagine 1 di 1
    • Disconnect both electro pump. Check were is white wire and black wire on each !!
  7. Daewoo DWC LDC1412S Water pump replacement Replacement: passo 7, immagine 1 di 1
    • Move last evacuation pipe on the new part
    • ...you can know mount the new part and try your new pump !!
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Thanks, this saved me heaps of money!!!
Brendan Innes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 107
Tutti i Tempi: 3,593
