Introduzione
LED lights are the lights on your device that turn on to send you different messages about the functioning of your electronic router. If the LED lights on your D-Link router are fading, inconsistent, or completely off at the power up of your device, replacement may be necessary. This step-by-step instructional guide will help you do just that.
Begin by placing the wired router face down.
  • Begin by placing the wired router face down.
  • Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
  • The two bottom plastic screw coverings do not need to be taken off.
Aggiungi Commento
Using a Philips PH2 screwdriver head, unscrew the two top screws.
  • Using a Philips PH2 screwdriver head, unscrew the two top screws.
Aggiungi Commento
Using a plastic opening tool, trace the edges of the router on all sides.  Gently pry the device until it eventually snaps open.
  • Using a plastic opening tool, trace the edges of the router on all sides. Gently pry the device until it eventually snaps open.
Aggiungi Commento
Once you have removed the top black case of the router, remove the silver casing surrounding the logic board. It should easily snap out of place.
  • Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
  • It should easily snap out of place.
Aggiungi Commento
Locate the two screws at the bottom of the logic board. Using the same PH2 head on your Philips screwdriver, unscrew these screws.
  • Locate the two screws at the bottom of the logic board.
  • Using the same PH2 head on your Philips screwdriver, unscrew these screws.
Aggiungi Commento
Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
  • Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
  • You have now removed the logic board from your device.
Aggiungi Commento
Locate the problematic LED light on the motherboard.
  • Locate the problematic LED light on the motherboard.
  • Using a plastic opening tool, very gently tilt its black base backwards.
Aggiungi Commento
Using your soft finger, tilt the LED light base backwards so that the actual light is facing upside down, at a 180 degree angle from the others. Using your soft finger, tilt the LED light base backwards so that the actual light is facing upside down, at a 180 degree angle from the others.
  • Using your soft finger, tilt the LED light base backwards so that the actual light is facing upside down, at a 180 degree angle from the others.
Aggiungi Commento
With a pair of tweezers, gently pry the LED light back and forth between its connecting wires until it is able to be removed.
  • With a pair of tweezers, gently pry the LED light back and forth between its connecting wires until it is able to be removed.
Aggiungi Commento
You should now have a removed LED light, ready to be replaced with a new one.
  • You should now have a removed LED light, ready to be replaced with a new one.
Aggiungi Commento
Conclusione
Jessica
Membro da: 19/09/2014
428 Reputazione
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 230
