Introduzione
Use this guide to assist with general disassembly or troubleshooting of your braille display.
Parti
Nessuna parte richiesta.
Remove the four bottom screws with a Phillips #00 screwdriver. Remove the four bottom screws with a Phillips #00 screwdriver.
  • Remove the four bottom screws with a Phillips #00 screwdriver.
Aggiungi Commento
Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset.
  • Remove the plastic cover, paper and chipset.
Aggiungi Commento
Remove the two screws with a Phillips #00 screwdriver on the logic board. take out the main circuit like show in the picture take out the main circuit like show in the picture
  • Remove the two screws with a Phillips #00 screwdriver on the logic board.
  • take out the main circuit like show in the picture
Aggiungi Commento
Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver.
  • Remove the four screws with a Phillips #00 screwdriver.
Aggiungi Commento
Remove the connector delicately. Remove the connector delicately. Remove the connector delicately.
  • Remove the connector delicately.
Aggiungi Commento
when you put it back together make sure mechanical cells are connected correctly when you put it back together make sure mechanical cells are connected correctly
  • when you put it back together make sure mechanical cells are connected correctly
Aggiungi Commento
Conclusione
Sisyphe
Membro da: 29/07/2013
332 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 430
