Parti
Nessuna parte richiesta.
Place the CygoLite on a flat surface with the bottom side facing up. Locate the four screws on the bottom of the device. Unscrew them with a Phillips head screwdriver and remove the bottom casing.
  • Place the CygoLite on a flat surface with the bottom side facing up.
  • Locate the four screws on the bottom of the device.
  • Unscrew them with a Phillips head screwdriver and remove the bottom casing.
Aggiungi Commento
Locate the rubber gasket on the side of the device. Place your new replacement rubber gasket onto the side of the casing and gently place the top of the case back on top of it.
  • Locate the rubber gasket on the side of the device.
  • Place your new replacement rubber gasket onto the side of the casing and gently place the top of the case back on top of it.
  • Be sure to line up the grooves in the casing with the grooves on the rubber gasket.
Aggiungi Commento
Conclusione
Trent Vigar
Membro da: 22/10/2012
101 Reputazione
1 Guida realizzata
Clemson, Team 14-3, Benson Fall 2012 Membro di Clemson, Team 14-3, Benson Fall 2012
CLEM-BENSON-F12S14G3
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 229
