Introduzione
The light bulbs on the device are prone to breakage and burn out. This guide provides information on how to replace the light bulbs.
Parti
Nessuna parte richiesta.
Place the device with the bottom facing upwards. Using a Phillips head screwdriver remove the screws on the bottom of the device.
  • Place the device with the bottom facing upwards.
  • Using a Phillips head screwdriver remove the screws on the bottom of the device.
Aggiungi Commento
Flip the device so that the top is facing upwards. Lift the top casing to expose the light. Lift the top casing to expose the light.
  • Flip the device so that the top is facing upwards.
  • Lift the top casing to expose the light.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Remove light out of the socket. Remove light out of the socket. Remove light out of the socket.
  • Remove light out of the socket.
Aggiungi Commento
Obtain a replacement bulb and plug it into the empty socket. Obtain a replacement bulb and plug it into the empty socket. Obtain a replacement bulb and plug it into the empty socket.
Aggiungi Commento
Conclusione
Kelly
Membro da: 22/10/2012
131 Reputazione
1 Guida realizzata
Clemson, Team 14-3, Benson Fall 2012 Membro di Clemson, Team 14-3, Benson Fall 2012
CLEM-BENSON-F12S14G3
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 566
