Introduzione
Control knobs are available in a wide variety of shapes, sizes, and materials and are used for various applications and come or can be designed in many configurations including instrument, pointer, skirted, large fluted with skirt, soft touch, and illuminated. Your replacement control knob should fit over a 6mm peg.
Unplug the power cable if it is plugged in so that you don't electrocute yourself or loved ones.
  • Unplug the power cable if it is plugged in so that you don't electrocute yourself or loved ones.
  • Make sure the turntable cover is closed so that nothing jostles out of place.
Aggiungi Commento
Using a spudger, gain a position of leverage and insert the end of the spudger into the gap between the radio knob and the device.
  • Using a spudger, gain a position of leverage and insert the end of the spudger into the gap between the radio knob and the device.
  • With some force, pry the knob off of its peg.
  • The knob should slide off smoothly, but beware of flying knobs!
Aggiungi Commento
Applying some force, insert the replacement knob onto the peg.
  • Applying some force, insert the replacement knob onto the peg.
Aggiungi Commento
Conclusione
Test by turning on your radio and playing a tune. We suggest "Last Dance" by Dona Summer.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 718
