Introduzione
If the metal hinge that props open the lid of the record player is damaged or broken, this will guide you through the process of removing and replacing the metal hinge.
Open the lid and find the door hinge.
  • Open the lid and find the door hinge.
Aggiungi Commento
Remove the two 12 mm screws that attach the hinge to the box. Remove the two 12 mm screws that attach the hinge to the box.
  • Remove the two 12 mm screws that attach the hinge to the box.
Aggiungi Commento
Remove the 2 screws that attach the hinge to the top of the box. When reassembling, it is easier to attach the top screws first and then the bottom screws.
  • Remove the 2 screws that attach the hinge to the top of the box.
  • When reassembling, it is easier to attach the top screws first and then the bottom screws.
  • The picture displayed is from disassembly and is only used to show the location of the bottom screws. The top screws should be attached first.
Aggiungi Commento
Conclusione
Jason
Membro da: 26/01/2014
103 Reputazione
1 Guida realizzata
Cal Poly, Team 1-38, Maness Winter 2014 Membro di Cal Poly, Team 1-38, Maness Winter 2014
CPSU-MANESS-W14S1G38
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 30
Tutti i Tempi: 1,274
