Parti
Nessuna parte richiesta.
Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges. The volume control button and the top power button may fall out during this step. The volume control button and the top power button may fall out during this step.
  • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
Aggiungi Commento
The left speaker is directly below the battery and on the side with the main red and black wires.
  • The left speaker is directly below the battery and on the side with the main red and black wires.
  • Unscrew the two 4mm Philips #00 screws using a Philips Screwdriver.
Aggiungi Commento
Once the screws are removed, discard the broken speaker. Replace the broken speaker with new left speaker.
  • Once the screws are removed, discard the broken speaker.
  • Replace the broken speaker with new left speaker.
Aggiungi Commento
Conclusione
Kyle
Membro da: 16/04/2013
111 Reputazione
2 Guide realizzate
Cal Poly, Team 14-10, Maness Spring 2013 Membro di Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 233
