Salta al contenuto principale
Creative Ziio 7" Battery Replacement
Cosa ti serve
  1. Creative Ziio 7" Battery Replacement, Back Panel: passo 1, immagine 1 di 3 Creative Ziio 7" Battery Replacement, Back Panel: passo 1, immagine 2 di 3 Creative Ziio 7" Battery Replacement, Back Panel: passo 1, immagine 3 di 3
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" Battery Replacement, Battery: passo 2, immagine 1 di 3 Creative Ziio 7" Battery Replacement, Battery: passo 2, immagine 2 di 3 Creative Ziio 7" Battery Replacement, Battery: passo 2, immagine 3 di 3
    • Remove the copper plate covering the motherboard by desoldering the ten solder points so that the copper plate is free.
    • The last point is hidden by the soldering iron.
    • Remove the copper plate once all the solder points are undone.
  3. Creative Ziio 7" Battery Replacement: passo 3, immagine 1 di 2 Creative Ziio 7" Battery Replacement: passo 3, immagine 2 di 2
    • Remove adhesive tape covering the three wires connected to the motherboard.
    • Desolder the solder points connecting the wires to the mother board.
  4. Creative Ziio 7" Battery Replacement: passo 4, immagine 1 di 2 Creative Ziio 7" Battery Replacement: passo 4, immagine 2 di 2
    • With a spudger, pry the battery from the back of the LCD screen.
    • The battery is attached with double sided foam tape. When prying, the tape will probably not come apart easy. This will result in the tape tearing and leaving residue.
  5. Creative Ziio 7" Battery Replacement: passo 5, immagine 1 di 1
    • Remove old battery and dispose of it responsibly.
Conclusione
Bryce Simmons
Membro da: 04/16/13
147 Reputazione
2 Guide realizzate
Cal Poly, Team 14-10, Maness Spring 2013 Membro di Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 955
