Introduzione
The LCD screen is an output component that displays information to the user.
Using a spudger, wedge the tip between the front and back case to pry them apart. Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together. Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  • Using a spudger, wedge the tip between the front and back case to pry them apart.
  • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
Aggiungi Commento
The black rubber button pad can be removed by simply picking it up.
  • The black rubber button pad can be removed by simply picking it up.
Aggiungi Commento
Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
Aggiungi Commento
Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
  • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
  • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
Aggiungi Commento
Lift open the LCD screen and button input chip to access the entire midsection plate.
  • Lift open the LCD screen and button input chip to access the entire midsection plate.
Aggiungi Commento
Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
Aggiungi Commento
Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
Aggiungi Commento
Lift the right edge of the motherboard off the back case. Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
  • Lift the right edge of the motherboard off the back case.
  • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
Aggiungi Commento
Use two fingers to peel back the edge of the ribbon connector that is glued to the bottom of the LCD screen. Use two fingers to peel back the edge of the ribbon connector that is glued to the bottom of the LCD screen.
  • Use two fingers to peel back the edge of the ribbon connector that is glued to the bottom of the LCD screen.
Aggiungi Commento
Using a plastic opening tool, unlock the ribbon connector by unlatching the black lever that pins it on the motherboard.
  • Using a plastic opening tool, unlock the ribbon connector by unlatching the black lever that pins it on the motherboard.
  • Once the black lever arm is open, pull the ribbon connector out to disconnect the LCD screen.
Aggiungi Commento
Conclusione
Westley Courchene
Membro da: 13/01/2015
2.620 Reputazione
14 Guide realizzate
USF Tampa, Team 1-1, Remmell Fall 2015 Membro di USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 602
